Acculution ApS
Certified Consultant
10 months ago
Jun 19, 2024, 3:46 a.m. EDT
If you go to Material, you can see that none of the materials that you have put are actually being used, since no tick marks are shown on the left column under Material Content. That is because under your physics (mf) all domains are assumed to be Free Space, and you can see in the Help that air or vacuum conditions are asssumed here. So you need add an Amperes law node to define your iron. Have a look at for example the small_signal_analysis_of_inductor.mph case in application library.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
10 months ago
Jun 21, 2024, 10:39 a.m. EDT
Thank you very much! Now the results make sense and I can move on to my main project. I had noticed that the Ampere's law node was present in some examples, but I thought the software automatically added all the necessary nodes. Thank you so much !!
