Eigenfrequency Prestressed not working
Hello I'm doing an Eigenfrequency Prestressed study of a rod and it is giving me this error
**Failed to find a solution. The relative residual (1.9) is greater than the relative tolerance. There was a warning message from the linear solver. Iterative refinement triggered. Returned solution is not converged. Not all parameter steps returned. **
here are the boundary condition that is given 1. The rod has a rigid connector boundary that constrained rotation in x y and z direction place at the bottom of the rod 2. the rod has an added mass boundary of 50 kg at the bottom of the rod 3. gravity is used, set at -9.82 m/s^2 in y direction 4. the material used is anisotropic silicon
The mesh is set at extra fine
attached is the rod mph.file that is used.
1 Reply Last Post Aug 22, 2024, 5:32 a.m. EDT
Posted: 3 months ago Aug 22, 2024, 5:32 a.m. EDT
The stationary load case cannot converge, since the model is underconstrained. All six rigid body motions must be suppressed.
Henrik Sönnerlind
COMSOL
Reply
