Kristian Ejlebjærg Jensen
COMSOL Employee
7 months ago
Oct 8, 2024, 4:12 a.m. EDT
Updated:
7 months ago
Oct 8, 2024, 6:20 a.m. EDT
Hi Casper
It is correct that the sensitivity study step only supports computation of a single sensitivity, but you can have several inner solutions with each their sensitivity, so you might get something close to what you want, if you
make an inner sweep with a parameter that does not affect the forward solution
use an iterative solver (so that the first forward computation can be somewhat recycled)
make the objective depend on the sweep parameter
Oftentimes, it is significantly easier and faster to solve optimization problems using the built-in COMSOL functionality. Is there anything preventing you from using one of the optimization study steps?
Kristian E. Jensen
Technical Product Manager, Optimization
Hi Casper
1. make an inner sweep with a parameter that does not affect the forward solution
2. use an iterative solver (so that the first forward computation can be somewhat recycled)
3. make the objective depend on the sweep parameter
Kristian E. Jensen
6 months ago
Oct 18, 2024, 5:47 a.m. EDT
Hi Casper
Kristian E. Jensen
Hi Kristian,
Thanks for the reply! I have tried the parametric sweep and function sweep, and also the iterative solver. One of the objectives, f1, consist of the first 6 eigenfrequencies, and the other objective, f2, is a simple volume integral of the control variable field. I swept some parameter k over a list containing 1's and 2's, and made the overall objective f = f1(k==1) + f2(k==2), so that it effectively switches between f1 and f2
I made sure that the solver saves solutions and reuses old ones, which does improve the efficiency somewhat for 'repeated' solves. However, it appears that every iteration of the sweep takes the same amount of time, even when I completely remove f1 (solid.freq) completely from the expression. Also, the iterative solvers for eigenfrequency (BigCGstab and GMRES) are significantly slower than the direct solver somehow.
As for the volume integral f2, it should not be dependent on the state-variable. I could define some dummy study that contains 'easy' physics, but still comsol does not allow a sensitivity analysis without physics.
Why not use the optimization module? Doing this would be ideal, and I have never noticed computational redundancy here (i.e. adding a volume integral and its sensitivity resulted in no extra computational time). Using the Matlab-LiveLink is partially just what some partners want (coupling it to their own software at some point), and continuation or control over certain parameters may be easier using external optimization. Most importantly however, I need modeshape-dependent objectives and sensitivities, which comsol does not yet support. The one solution to everything would be to just export matrices and solve externally, at a significant cost of implementation ease ):
Kind regards,
Casper
>Hi Casper
>Best regards,
>Kristian E. Jensen
Hi Kristian,
Thanks for the reply! I have tried the parametric sweep and function sweep, and also the iterative solver. One of the objectives, f1, consist of the first 6 eigenfrequencies, and the other objective, f2, is a simple volume integral of the control variable field. I swept some parameter k over a list containing 1's and 2's, and made the overall objective f = f1*(k==1) + f2*(k==2), so that it effectively switches between f1 and f2
Kind regards,
Casper
