I have discovered a potential bug
Posted Oct 15, 2024, 10:27 p.m. EDT 3 Replies
After adding the two physics interfaces for mass transfer in porous media (tds) and solid mechanics(solid), I found that the hygroscopic expansion module(hs1) cannot select the object from the multiphysics point. It seems to be a clear bug.
However, by replacing the physical field of mass transfer in porous media with the physical field of mass transfer, the problem is solved naturally
