Modeling of a cantilever beam surrounded by air with the application of an initial deformation and an electrostatic force
Hello, I’m a beginner with COMSOL, and I’m trying to model a cantilever beam in the MEMS module, applying an initial deformation and an electrostatic force. For the initial deformation, I tried imposing either an initial stress and strain or a prescribed displacement in the Solid Mechanics physics, and I managed to achieve the deformation I wanted. For the electrostatic force, I applied a voltage using the Terminal option on the beam and grounded the air block below the beam. Finally, I added the Moving Mesh physics with the Deforming Domain option on the air to make it move according to the beam.
Unfortunately, when I run the simulation, I encounter the following error that I am unable to resolve: - Feature: Stationary Solver 1 (sol1/s1) Undefined value found. - Detail: Undefined value found in the equation residual vector. There are 921 degrees of freedom giving NaN/Inf in the vector for the variable comp1.spatial.u. at coordinates: (0.000231,2e-05,4.8e-06), (0.0002345,2e-05,4.8e-06), (0.000238,2e-05,4.8e-06), (0.000231,2e-05,6.1875e-06), (0.000231,2e-05,7.575e-06), ...
There are 921 degrees of freedom giving NaN/Inf in the vector for the variable comp1.spatial.v. at coordinates: (0.000231,2e-05,4.8e-06), (0.0002345,2e-05,4.8e-06), (0.000238,2e-05,4.8e-06), (0.000231,2e-05,6.1875e-06), (0.000231,2e-05,7.575e-06), ...
There are 921 degrees of freedom giving NaN/Inf in the vector for the variable comp1.spatial.w. at coordinates: (0.000231,2e-05,4.8e-06), (0.0002345,2e-05,4.8e-06), (0.000238,2e-05,4.8e-06), (0.000231,2e-05,6.1875e-06), (0.000231,2e-05,7.575e-06), ...
I noticed that by significantly reducing the initial deformation, the model works, but I don’t know why.
Do you have any ideas on how I could solve this? Thank you in advance
1 Reply Last Post Feb 24, 2025, 8:13 p.m. EST
Hello Alberto Micele
Posted: 2 months ago Feb 24, 2025, 8:13 p.m. EST
Hi, I have encountered the same problem as yours. May i ask have you solved it? Also you can have a look on the post below https://www.reddit.com/r/COMSOL/comments/1i2llah/moving_mesh_problem/ It probably have the same question with you. I think the main reason is on the moving mesh feature but I have no idea on solving it.
Reply
