EM waves signals
Hello there,
I have an empty steel square box, 50 cm * 50 cm * 50 cm in size, the thickness of the steel plate 2mm. I want to introduce an EM wave source inside the box, like a Gaussian pulse in the order of ns, to observe the attenuation or reflections of EM waves inside and outside the box as time goes on. Besides, there are some holes on the surfaces of the box, and as such, the EM waves should go out through the holes and spread over the outer surface of the box and surroundings. My question is, how can I define the boundary condition in my case study, with an EM source and a box? In transient, there is only the PEC boundary condition.
10 Replies Last Post Nov 9, 2024, 3:08 a.m. EST
Posted: 6 months ago Nov 7, 2024, 4:58 p.m. EST
I very rarely used the temw mode so I had forgotten there was no selection for an imperfect conductor.
You will be able to obtain some insight using the perfect conductor boundary condition. However you should consider doing a frequency-dependent calculation which contains complementary information. In principle it would be possible to use those results to perform an inverse Fourier transform to get the time response.
I very rarely used the temw mode so I had forgotten there was no selection for an imperfect conductor. You will be able to obtain some insight using the perfect conductor boundary condition. However you should consider doing a frequency-dependent calculation which contains complementary information. In principle it would be possible to use those results to perform an inverse Fourier transform to get the time response.
Posted: 6 months ago Nov 7, 2024, 6:58 p.m. EST
Actually, I need to see the transient behavior of EM waves over time to see how they propagate. A frequency-dependent solution might not be suitable for my case study.
Posted: 6 months ago Nov 8, 2024, 2:44 a.m. EST
David suggests to perform a sufficiently broad and fine frequency scan and do a an inverse Fourier transform to obtain the time dependency. You will need to make yourself familiar with Fourier transform theory. The window function which is the Fourier transform of the time dependent excitation is key. It works, I have done it in acoustics models. But it is not exactly plug and play.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
David suggests to perform a sufficiently broad and fine frequency scan and do a an inverse Fourier transform to obtain the time dependency. You will need to make yourself familiar with Fourier transform theory. The window function which is the Fourier transform of the time dependent excitation is key. It works, I have done it in acoustics models. But it is not exactly plug and play. Cheers Edgar
Posted: 6 months ago Nov 8, 2024, 9:19 a.m. EST
In principle, you can also model the walls (to perhaps a couple of skin depths?) as fully meshed domains within a time domain model, since the temw formalism will allow you to specify a finite conductivity of a domain. This may or may not be practical computationally in your model. If you do take this approach, be sure to define the mesh of the lossy wall volumes carefully, so as to properly model the field gradients in the vicinity of the skin depth, yet not run out of memory. This will be easier if you can do a 2D model instead, or make any other use of symmetry.
In principle, you can also model the walls (to perhaps a couple of skin depths?) as fully meshed domains within a time domain model, since the temw formalism *will* allow you to specify a finite conductivity of a domain. This may or may not be practical computationally in your model. If you do take this approach, be sure to define the mesh of the lossy wall volumes carefully, so as to properly model the field gradients in the vicinity of the skin depth, yet not run out of memory. This will be easier if you can do a 2D model instead, or make any other use of symmetry.
Posted: 6 months ago Nov 8, 2024, 1:31 p.m. EST
Is there any example or article about this principle? Actually, I a little bit confused about your explanations.
Posted: 6 months ago Nov 8, 2024, 3:12 p.m. EST
Updated: 6 months ago Nov 8, 2024, 3:19 p.m. EST
See the example attached. This example is not optimized for any purpose in particular. A single cycle of RF is launched by a post inside a square cavity, and then it bounces around in the cavity. There is one lossy domain (note that sigma = 1.0 S/m in the rectangle on the right-hand side). This is only a 2D model. I included a probe to show how the energy in the cavity varies with time (see the Results section, to plot that). All that said, I encourage you to follow the suggestions made by David Greve and Edgar Kaiser above, if you can! They know what they are talking about.
See the example attached. This example is *not* optimized for any purpose in particular. A single cycle of RF is launched by a post inside a square cavity, and then it bounces around in the cavity. There is *one lossy domain* (note that sigma = 1.0 S/m in the rectangle on the right-hand side). This is only a 2D model. I included a probe to show how the energy in the cavity varies with time (see the Results section, to plot that). All that said, I encourage you to follow the suggestions made by David Greve and Edgar Kaiser above, if you can! They know what they are talking about.
Posted: 6 months ago Nov 8, 2024, 3:37 p.m. EST
Very nice example Robert!
Cheers Edgar
Edgar J. Kaiser
www.emphys.com
Very nice example Robert! Cheers Edgar
Posted: 6 months ago Nov 8, 2024, 4:14 p.m. EST
The finite-conductivity approach suggested by Robert will probably be most accurate for a limited range of frequencies, where the skin depth is of the order of the mesh size. So if the exciting waveform is nearly a delta function (with a wide spread in the frequency domain) this would not be the best approach. On the other hand a windowed sinusoid would work very well with the finite-conductivity wall.
If OP chooses to mesh the wall it will be necessary to be very judicious with the approach used. Probably a swept mesh is the way to go.
If the holes are large enough (so that propagation outside is dominant) it may not even be necessary to model dissipation within the box.
The finite-conductivity approach suggested by Robert will probably be most accurate for a limited range of frequencies, where the skin depth is of the order of the mesh size. So if the exciting waveform is nearly a delta function (with a wide spread in the frequency domain) this would not be the best approach. On the other hand a windowed sinusoid would work very well with the finite-conductivity wall. If OP chooses to mesh the wall it will be necessary to be very judicious with the approach used. Probably a swept mesh is the way to go. If the holes are large enough (so that propagation outside is dominant) it may not even be necessary to model dissipation within the box.
Posted: 6 months ago Nov 8, 2024, 7:45 p.m. EST
Updated: 6 months ago Nov 8, 2024, 7:46 p.m. EST
Thanks Robert. Actually I defined four walls made of copper (not lossy) and put a air gap on the surface. EM wave should be spreads out from this gap but it doesn't work. I attached the file. I appreciate it if you take a look of it.
Posted: 6 months ago Nov 9, 2024, 3:08 a.m. EST
Updated: 5 months ago Nov 11, 2024, 4:06 a.m. EST
The gap is leaking radiation, it is just not very well visible in the linear plot. I often plot log10(normE) to visualize fields over a large range.
I made a little animation that shows the effect.
Edgar J. Kaiser
www.emphys.com
The gap is leaking radiation, it is just not very well visible in the linear plot. I often plot log10(normE) to visualize fields over a large range. I made a little animation that shows the effect.
Reply
