Feb 6, 2013, 12:59 a.m. EST
if you check the doc, and the Forum you will see that "s" is a COMSOL internal variable taking the value 0 to 1 along a 2D boundary. so if you select an edge in 2D (=a boundary) and write a velocity 4*s*(1-s)*Umax you get an parabolic profile with u=0 at s=0 and s=1 (the walls intersection points) and a velocity Umax at s=0.5 the middle of the edge/boundary
This is a good starting velocity profile for FCD for a pipe or any fluid flowing between two (no-slip) walls
Jun 29, 2015, 9:55 a.m. EDT
Dear Ivar
First question:
In examples I encountered
4*s*(1-s)*Umax
versus
6*s*(1-s)*Umax
As the average of s*(1-s) is 1/6, I assume 6*s*(1-s) is the best choice as it gives you U_max at s=0.5?
Or why do you propose 4*s*(1-s)?
Second question:
Why use 6*s*(1-s)*Umax
and not (-4*(s-0.5)^2+1)*Umax?
I admit, your expression is shorter, however, the velocity profile is parabolic, so of the form a*x^2 (and not a*x^2+b*x).
Third question:
I have an inlet with a symmetry plane. I select the inlet boundary to give it a velocity profile that is half of 6*s*(1-s)*Umax . But 's' always goes up to 1. Do I use 6*s/2*(1-s/2)*Umax to get half of the profile?
Thx
Dear Ivar
First question:
4*s*(1-s)*Umax
versus
6*s*(1-s)*Umax
Second question:
Third question:
Thx
