COMSOL Error Message
I've been problems with COMSOL in Plasma Module
The following feature has encountered a problem:
"The source selection for the operator intpot1 must be nonempty. Error in multiphysics compilation.
- Feature: Compile Equation : Time Dependent (Sol1/st1)
- Error: The source selection for the operator intpot1 must be nonempty"
Would you mind to help me?
Thanks you very much
Natthawut
2 Replies Last Post Feb 6, 2013, 8:10 p.m. EST
Posted: 1 decade ago Feb 6, 2013, 10:00 a.m. EST
Natthawut,
You did not select any domain or boundary when you defined integration operator under Definition/Model Coupling/Integration.
Sergei
Natthawut, You did not select any domain or boundary when you defined integration operator under Definition/Model Coupling/Integration. Regards, Sergei
Posted: 1 decade ago Feb 6, 2013, 8:10 p.m. EST
Thank you sir
I modified the program to run. I also have a error message following
"Repeated error test failures. May have reached a singularity.
Time : 6.331016568333548e-009
Undefined value found.
Undefined value found in the stiffness matrix.
There are 2 equations giving NaN/Inf in the matrix rows for the variable mod1.wAr_1p.
at coordinates: (2.3612e-005,9.08325e-005), (2.15237e-005,8.63755e-005), ...
and similarly for the degrees of freedom, NaN/Inf in the matrix columns.
- Feature: Time Dependent (Sol1/st1)
- Error Repeated error test failures. May have reache a singularity"
Best Regards
Natthawut
Thank you sir I modified the program to run. I also have a error message following "Repeated error test failures. May have reached a singularity. Time : 6.331016568333548e-009 Undefined value found. Undefined value found in the stiffness matrix. There are 2 equations giving NaN/Inf in the matrix rows for the variable mod1.wAr_1p. at coordinates: (2.3612e-005,9.08325e-005), (2.15237e-005,8.63755e-005), ... and similarly for the degrees of freedom, NaN/Inf in the matrix columns. Last time step is not converged. - Feature: Time Dependent (Sol1/st1) - Error Repeated error test failures. May have reache a singularity" Would you mind to help me? Best Regards Natthawut
