Feb 12, 2013, 10:59 a.m. EST
I might not have really understood you, but in Definitions functons "rect" the rectangle function should allow you to define pulse width rise/fall time, amplitude, the with an analytical function calling this rect you can make it "periodic" (perhaps also directly with the rect, check the "sub tabs" I'm not by my COMSOl workstation.
You reeat the same for the second pulse, and then you call the different ports with a +/-ana1(t[1/s]) or +/-rect1(t[1/s]) and that should work, ... no ?
Feb 18, 2013, 5:30 p.m. EST
Hi Ivar,
Thank you for your response. I tried using rectangle functions; however, there was no way that I could find in which to change the amplitude. I was able to change the pulse width and rise/fall time though.
After thinking about what you had said, I ended up using a series of step functions that I than added together in an analytic function. When I generate the plot, the waveform appears to be correct. Thanks for your help.
Eric
Hi Ivar,
Eric
Feb 19, 2013, 12:56 a.m. EST
you can either multiply your rect1(...) function something like A0*rect1(...), or you could add an analytical function where you add the amplitude and call the rect1(...) function
Oct 27, 2014, 10:51 a.m. EDT
Hello Mr.Ivar,
Can you please help me in creation of new waveform. I would like to create a step function waveform to use it in analytic expression. We have only square, triangular, sawtooth and sine function wave forms in comsol. But I would like have only positive step function.
How can I create it. I tried in create plot, but I could not able to simulate it. Can you please help me out.
Thanking you.
Meera kunden
Hello Mr.Ivar,
Thanking you.
Meera kunden
9 years ago
Aug 23, 2016, 5:45 a.m. EDT
Hello Meera Kunden,
I came to know that you were looking for ways to generate a positive step function waveform on the forum and i am working on a similar project.
Have you been able to generate it?
Would you like to share your knowledge?
Warm regards,
Nikita Bansal
Hello Meera Kunden,
Warm regards,
Nikita Bansal
