Guidance on Adaptive Closed-Loop Stimulation Current Simulation
I am working on a simulation project involving adaptive closed-loop stimulation in using LiveLink to integrate feedback from the system to control the terminal source (electrode stimulation). I would appreciate any insights or guidance from the community. Specifically, I am interested in simulating an electrode-based stimulation system (interpolated waveform function as a terminal) where the current is applied adaptively based on feedback from the system. The feedback could be related to electric fields, voltage changes, or other measurable parameters.
Key questions: * Can anyone provide insights on implementing adaptive feedback control in COMSOL, particularly how to modify the electrode stimulation dynamically in response to field data (e.g., based on measured voltage)? * Are there any known issues or common pitfalls when solving time-dependent simulations that involve feedback from the electric field or voltage measurements?
If anyone has successfully implemented adaptive control systems or closed-loop stimulation in COMSOL using LiveLink for MATLAB, I would love to hear about the methods or algorithms you used.
1 Reply Last Post Jan 11, 2025, 3:20 a.m. EST
Posted: 3 months ago Jan 11, 2025, 3:20 a.m. EST
Sophia,
you can make boundary conditions depend on model quantities. You can e.g. use probes to measure a certain quantity at a specific location, or you can use nonlocal couplings to generate a quantity for the control loop. Here are two COMSOL blog contributions you may find interesting:
https://www.comsol.com/blogs/using-the-previous-solution-operator-in-transient-modeling I have been using this approach in the past.
This is something new in version 6.3 and I haven't used it so far: https://www.comsol.com/blogs/solving-delay-differential-equations-to-model-marmots Looks very interesting.
Not sure if you need to use Matlab for your project.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Sophia, you can make boundary conditions depend on model quantities. You can e.g. use probes to measure a certain quantity at a specific location, or you can use nonlocal couplings to generate a quantity for the control loop. Here are two COMSOL blog contributions you may find interesting: https://www.comsol.com/blogs/using-the-previous-solution-operator-in-transient-modeling I have been using this approach in the past. This is something new in version 6.3 and I haven't used it so far: https://www.comsol.com/blogs/solving-delay-differential-equations-to-model-marmots Looks very interesting. Not sure if you need to use Matlab for your project. Cheers Edgar
Reply
