Apparent inconsistency in induction heating solution methods
Posted Feb 15, 2013, 7:19 p.m. EST Electromagnetic Heating Version 4.3 10 Replies
I'm new to COMSOL 4.3, and I'm trying to properly use the induction heating module. While modeling the problem of a current loop heating several iron inductors embedded in water in 3D, using either External Current Density or Surface Current, I kept getting temperatures that I strongly suspected were too low. I modeled a similar problem of one inductor in axisymmetric 2D, with the intention of comparing heating via Single-Turn Coil Domain with heating from either of the aforementioned methods. I get a result that seems right to me with Single-Turn Coil Domain, but when I deactivate it and activate either External Current Density or Surface Current, I get a temperature rise of less than a degree, a similar wrong result to what I get with 3D modeling.
With External Current Density, I use the current (1000 A) divided by the cross-sectional area of the loop wire, and I use the current divided by the circumference of the loop wire when I use Surface Current instead.
I've attached the 2D axisymmetric version of the test problem that delivers incorrect results. I've slightly modified the materials such that water has a relative permittivity and permeability both of 1, and an electrical conductivity of 0.1 S/m. Can anyone let me know what I'm missing? Thanks in advance!
Here's a simple 3D version of the problem that has the same issue. Can someone help me with this problem?
I'm not sure it all wrong, but first of all in your 3D model your mesh is too coarse, I get a factor 2.5-3x more induced power by going to "extremely fine" meshing for the small target part, and as your total resistive loss in your coil is only 10 mW I'm not astonished that you get a low induced power either. Now integrating your 13A/mm^2 dissipating over the coil resistance gives about 15W in DC mode, remains to ask what happens at 125 kHz with the impedance ?, could that be the factor roughly 1000 ? Just the section of the coil compared to your target object has a ratio of about (7/0.1) = 4900 so you are not really using efficiently your magnetic field either
by the way you do not seem to use the variable "mu_core", but for me it has a problem of sign for T>320K it becomes negative, not sure that is what you want
note: by using a user defined cylindrical coordinate system it's easier to define the external current along "phi"
Sorry no clear answer I would have to reconstruct it fully, but I do not see why COMSOL should get it wrong, if the model is set-up correctly ;)
Thanks for helping with my problem. The function "mu_core" is a leftover from a previous version of the problem, which involves a relative magnetic permeability that varies with temperature. (I had not considered that it is negative at high temperatures; I'll have to address that in future modeling.) I eliminated that feature so my example file included only the basics.
I had experimented with different meshes for Surface Current, but I found that the final temperature did not converge to a specific value with mesh size; it increased by a uniform amount in each step when I increased the mesh from "normal" up to "extremely fine."
By the way, are you aware of limitations of the induction heating module at low currents or ~100 kHz frequencies? My research group has an industrial induction heater that is capable of turning small steel objects red-hot within seconds, while acting at a frequency of ~100 kHz and less than 20 amperes (corresponding, with the induction coil we are using, to an H-field of approximately 1000 A/m at the current peak). However, I am only able to produce significant heating with COMSOL modeling when the input current is at least an order of magnitude above what the machine is putting out.
Thanks for your help!
well are you sure you have the correct numer of turns in your coil ?,
the only issue I see could be linked to the resonance frequency of the coil and its impedance, that is frequency dependent, check that your model matches the R and L values of your coil
My test with the mesh was to only mesh the target "extremely fine" I didnt change the rest, that made quite some difference, but still not what you are talking about ;)
I tried modeling the loop as a hollow copper tube, instead of like a solid piece like in the original 2D axisymmetric model I uploaded. Changing the thickness of copper in a tube of constant outer diameter does not change the results for heating when Single-Turn Coil Domain is used, so that seems to imply that resistance of the loop does not affect the results. Do you think other parameters that we aren't accounting for could possibly be at work?
The model I referred to earlier (reproducing the induction heater used by our group) is almost exactly the same as the model I uploaded, with the exception that I am using 6 loops and the loop diameter is a little different. I can upload that one if you feel it's relevant; do you think it's better to work out this simple one-loop model first? (We also have a single-loop inductor for our heater that is easily capable of making a nail red-hot at ~15 amperes and ~300 kHz.)
Thanks !
for me the main issue of your original file was the mesh of the target, not the source, surface current or bulk is not canging anything, but the way you calculate the current yes, how many turns, which current density in the coil, wire diameter and overall size. Then the frequency, is it correct, Finally is the surrounding lage enouh to allow the field to loop around ?
Have you tried to compare the results of COMSOL with analytical results ?
Sorry for taking so long to reply; I've been busy with deadlines lately. I was able to converge toward a solution by decreasing the mesh size to an extremely small value; however, the heating is much less than what I expect from experiments with our induction heater. I followed your advice of increasing the volume surrounding the heater and workpiece to make room for the magnetic field lines. This increased the maximum temperature, but it is still too low. Also, the result from Single-Turn Coil Domain does not agree with the results from External Current Density and Surface Current. I followed your advice of obtaining analytical results with which to compare, but the analytical results also suggest a much higher maximum temperature than what I have been able to find. (I used the formulas provided here: www.thermopedia.com/content/874/ They seem to agree that what I've found experimentally.)
To sum up, the heating from Single-Turn Coil Domain is significantly lower than what I expect, and the other methods of calculating heating are even lower. I am attaching the model of our induction heater to this post.
Thanks in advance for your help, and thanks again for your time and patience so far!
I also used Coil-Group Domain to attempt to accurately model the heating, but obtained similar results to Single-Turn Coil Domain. Analytical calculations suggest that the power generation should be nearly two orders of magnitude greater than what COMSOL has calculated so far. Any further help is greatly appreciated!
Did you find a solution?
Thank you
Patrice Gouin
