Heat in inductor using Induction Heating
Posted Feb 19, 2013, 6:04 a.m. EST Heat Transfer & Phase Change Version 4.3 1 Reply
I'm working on a model to see the temperature in all of the parts within the inductor. Since I'm using the Induction Heating physics I have to excite the inductor using Lumped Ports. However the simulation only converges when I put one of the boundaries of the big box that surrounds the inductor to a specific temperature.
The questions I have are:
- Is the excitation correct if I want to compare the results with measurements done in real life?
- How can I get around the need to put a boundary to a fix temperature since this isn't accurate with real life?
- Are there any improvements i can do to my model for an even more accurate solution?
I'm currently using COMSOL 4.3, the model geometry is taken from the Model Library > AC/DC module > Inductive devices and coils > inductor_3d.mphbin and the meshing is a Coarse, Physics-controlled mesh.
Thank you in advance
1 Reply Last Post Mar 3, 2013, 10:28 a.m. EST
