How can I select a point as a source of my prescribed velocity in a 2D geometry?
Hello. I'm using the Elastic Waves module and I'm trying to simulate the wave propagation with a point source, but I don't know how to select the point when I'm selecting a boundary in the Prescribed Velocity.
5 Replies Last Post Feb 20, 2025, 6:33 p.m. EST
Posted: 4 days ago Feb 18, 2025, 4:28 p.m. EST
It's as simple as inserting a point in the geometry at the desired location. Look under Geometry>More Primitives.
Posted: 4 days ago Feb 18, 2025, 4:43 p.m. EST
I've already done that in the attached file. But I don't know how to select it in the Prescribed velocity section
>It's as simple as inserting a point in the geometry at the desired location. Look under Geometry>More Primitives. I've already done that in the attached file. But I don't know how to select it in the Prescribed velocity section
Posted: 4 days ago Feb 18, 2025, 7:10 p.m. EST
I don't have 6.3 on this machine so I can't look at your file.
In 6.2 right-click Solid Mechanics then select Points>Prescribed Displacement.
That is- you must select a point, not a boundary.
I don't have 6.3 on this machine so I can't look at your file. In 6.2 right-click Solid Mechanics then select Points>Prescribed Displacement. That is- you must select a point, not a boundary.
Posted: 3 days ago Feb 19, 2025, 6:44 p.m. EST
But I'm working with the Elastic Waves module. I want to propagate the wave from a point as a source
>I don't have 6.3 on this machine so I can't look at your file. > >In 6.2 right-click Solid Mechanics then select Points>Prescribed Displacement. > >That is- you must select a point, not a boundary. But I'm working with the Elastic Waves module. I want to propagate the wave from a point as a source
Posted: 2 days ago Feb 20, 2025, 6:33 p.m. EST
I have never used the elastic waves time explicit module although I have extensively modeled wave propagation in the solid mechanics module.
I had a look at your file in 6.3 and it does not appear to be possible to apply a prescribed displacement condition to a point. I suggest you contact support to see if (1) my interpretation is correct and (2) if there is an alternate approach to your problem.
I have never used the elastic waves time explicit module although I have extensively modeled wave propagation in the solid mechanics module. I had a look at your file in 6.3 and it does not appear to be possible to apply a prescribed displacement condition to a point. I suggest you contact support to see if (1) my interpretation is correct and (2) if there is an alternate approach to your problem.
Reply
