Transient magnetic field: mimic a wire
Hello, I have built a solid mechanics and magnetic fields multiphysics simulation. At a high level, the simulation includes a current-carrying wire (that generates a magnetic field), and a small, soft-magnet device at some distance from the wire. In the presence of the magnetic field, I study the deformation of the soft magnetic structure.
I now want to do this simulation in a transient domain, however I would like to eliminate the need to simulate the field from the wire. Instead, I would like to specify or easily generate a field with the same exact profile as the wire. The reason for this is that COMSOL is giving me trouble when I attempt to study the coupled physics involving the current carrying wire while in a transient domain. If I can instead specify a transient magnetic field (not coming from a wire, just a "magic" field, if you'd like), then I can avoid this problem.
I have made this field already by using the MFNC module and specifying the Hx Hy and Hz. It runs fine. However, I am wondering if there is/are better ways to do this?
Thank you.
1 Reply Last Post Apr 1, 2025, 8:12 p.m. EDT
Posted: 4 weeks ago Apr 1, 2025, 8:12 p.m. EDT
After first talking about the field from the wire, you then said that you have made the field by specifying Hx, Hy, and Hz, and it runs fine. So, if I understand that correctly, it sounds like you succeeded in specifying the "magic field" just as you wanted. Do you still envision that there is or should be a "better way"? Is there something else you would like to accomplish, but which isn't already working as you wish?
Reply
