Split Ring Resonator!!!
Hi all,
Iam trying to design a Split Ring Resonator(a spiral ) for my project. Iam struggling with it, as iam very new to comsol.
Can any one help me how to start with it. To add more it has to have a inner circle too.
2 Replies Last Post Dec 19, 2013, 1:09 a.m. EST
Posted: 1 decade ago Feb 27, 2013, 11:51 a.m. EST
It sounds like this might be your first experience with comsol, so I know it can be intimidating. Basically, you'll want to use the "geometry" subnode to draw what you want as your first step.
What I do is define a "block" of the dimensions of a unit cell, and whose thickness is equal to my substrate thickness.
Then i use "work plane" goemetry feature to draw on the top (and/or bottom) surfaces exactly the trace pattern I want. In your case, it's a spiral. I think the "parametric" surface might be a way for you to do that...but spirals in 2D can be hard since unlike 3D there's no built in spiral feature (there's a helix feature for 3D).
You can also use your favorite CAD software to draw what you want and save it in a file type that comsol allows for import...
After that you'll want to assign material properties and boundary conditions for whatever problem you're trying to solve....
Hope that helps for a start!
--matt
It sounds like this might be your first experience with comsol, so I know it can be intimidating. Basically, you'll want to use the "geometry" subnode to draw what you want as your first step. What I do is define a "block" of the dimensions of a unit cell, and whose thickness is equal to my substrate thickness. Then i use "work plane" goemetry feature to draw on the top (and/or bottom) surfaces exactly the trace pattern I want. In your case, it's a spiral. I think the "parametric" surface might be a way for you to do that...but spirals in 2D can be hard since unlike 3D there's no built in spiral feature (there's a helix feature for 3D). You can also use your favorite CAD software to draw what you want and save it in a file type that comsol allows for import... After that you'll want to assign material properties and boundary conditions for whatever problem you're trying to solve.... Hope that helps for a start! --matt
Posted: 1 decade ago Dec 19, 2013, 1:09 a.m. EST
Respected sir,
I am R.Karthik raja pursuing my M.Tech. I am doing my final year project on Split ring resonator in COMSOL. I am finding difficult to build it in it and it will be useful if someone provides step by step process for building it.
Respected sir, I am R.Karthik raja pursuing my M.Tech. I am doing my final year project on Split ring resonator in COMSOL. I am finding difficult to build it in it and it will be useful if someone provides step by step process for building it.
