2 decades ago
Mar 1, 2010, 1:58 a.m. EST
1st hint:
www.comsol.com/support/knowledgebase/952/
I am having these kind of problems too. One thing that *seems* to be working is to run a steady-state beforehand, and then running transient, in addition to the comments above.
please keep me updated with your progress.
1st hint:
http://www.comsol.com/support/knowledgebase/952/
2 decades ago
Mar 1, 2010, 1:57 p.m. EST
So I've referred to the link and tried the recommendations.
No change when using a finer mesh. No change when using the flc2hs function.
The next thing I tried was solving the Navier-Stokes equations first and then solving the Diffusion equations, rather than solving simultaneously. This also had no effect.
I didn't try using the log(c) as I'm not sure how to implement this. I'll check out the sample model and update with any success.
2 decades ago
Mar 1, 2010, 5:26 p.m. EST
I have attempted the logarithmic definition of the concentration boundary conditions but it doesn't have any effect. I'm not sure how it would possible maintain a positive value just by defining the boundary as log(1) instead of zero, or log(10) instead of one. Is there a way to define concentration as log(c)? In other words, how do I define the dependent variable?
Update: Dependent variable needed to be selected in the Model Navigator. I changed the dependent variable to C and defined a scalar expression c=exp(C). Running the solver now. I'll update if it works.
2 decades ago
Mar 1, 2010, 6:29 p.m. EST
also try anisotropic streamline diffusion (0.1), in case.
2 decades ago
Mar 2, 2010, 1:25 p.m. EST
Using log(c) keeps the concentration positive. However the maximum concentration still peaks to 10^5 or higher (with an inlet concentration of 100).
I'm trying the anisotropic diffusion tuning parameter 0.1.
2 decades ago
Mar 3, 2010, 9:42 a.m. EST
one more thing that my help is to run a steady-state before a transient simulation, and use it as initial conditions.
Mar 23, 2010, 6:50 a.m. EDT
Hello.
I am experiencing the same problem: I designed a passive micromixer and want to check its efficiency. Using the Incompressible Navier-Stokes model first, then applying the Convection/Diffusion one seems to work.
But as well, the concentration range is impossible: sometimes -40 to 200 whereas I put respectively 0 and 10 at my inlets. Also, observing the concentration at the outlet subdomain, I find concentrations between 2.05 and 2.10 (something like that), which is absurd: it should be centered around 5.
It seems there is a problem of mass/matter conservation. Any idea to solve that issue?
Many thanks.
Hello.
Many thanks.
Jun 15, 2010, 8:50 a.m. EDT
I am having this problem as well. Whenever I choose the 'flux' boundary condition the concentration builds up to a physically impossible level. However, when I choose the 'concentration' condition it works out fine. I've attached my model of pore-scale mixing. It seems to be a fairly common problem... can anyone help to resolve this issue?
Thanks!
-Tim
Thanks!
-Tim
Jun 15, 2010, 8:53 a.m. EDT
Sorry... problems in attaching my model. Hopefully it works now...
