Comsol RF module norm and phase
Dear all,
I have a problem with Comsol, a very naive one.
I am trying to do a harmonic simulation (a single frequency in frequency domain model) of the EM scattering in a domain.
For example if I have a electric dipole oscillating in a square medium. I will be able to get the norm of the electric field at any spatial point in the simulated domain by selecting the norm option in Comsol. However I am also interested in finding out the relative phase relationship between the electric field at different spatial points. If there a easy way to do it say by selecting any function in the Comsol simulation ?
All the best
6 Replies Last Post Mar 4, 2013, 2:06 p.m. EST
Posted: 1 decade ago Mar 3, 2013, 6:19 p.m. EST
look at the spatial components of the electric field. They are complex. You may have to use the real() and imag() operators.
Cheers
Edgar
Hi, look at the spatial components of the electric field. They are complex. You may have to use the real() and imag() operators. Cheers Edgar
Posted: 1 decade ago Mar 3, 2013, 6:22 p.m. EST
Thank you Edgar,
I did not find the phase (complex) option in the Comsol interface so
I assume now if I export these field numbers into matlab they will be complex
Is that correct ?
Thank you so much for your reply
Thank you Edgar, I did not find the phase (complex) option in the Comsol interface so I assume now if I export these field numbers into matlab they will be complex Is that correct ? Thank you so much for your reply
Posted: 1 decade ago Mar 4, 2013, 1:09 a.m. EST
you should check the help "mathematical functions" and "special operators", there you can fine the imag() real() arg atan2(,) ... and many more
Hi you should check the help "mathematical functions" and "special operators", there you can fine the imag() real() arg atan2(,) ... and many more -- Good luck Ivar
Posted: 1 decade ago Mar 4, 2013, 6:07 a.m. EST
Ivar is right, try atan(imag()/real()) and you get the phase
Posted: 1 decade ago Mar 4, 2013, 6:10 a.m. EST
Thank you for your reply, I will check it out
Best wishes
Thank you for your reply, I will check it out Best wishes
Posted: 1 decade ago Mar 4, 2013, 2:06 p.m. EST
to get the full 2*pi rad turn use rather
arg( your_compl_var )
or
atan2( imag(your_compl_var) , real(your_compl_var) )
and NOT atan(.../...) that is limtied to 0-pi rad
Hi to get the full 2*pi rad turn use rather arg( your_compl_var ) or atan2( imag(your_compl_var) , real(your_compl_var) ) and NOT atan(.../...) that is limtied to 0-pi rad -- Good luck Ivar
