How to generate pulsed laser in Bioheat Eq.
For Bioheat equation, there is one parameter which I can input corresponding to laser source, Q_ext (spatial heat source)
In this part, I typed the equation of laser radiation below,
I0*a*exp(a*z-r^2/(2*sigma^2))
and this is all what I could do.
The laser of course radiated as CW(continuous wave) mode.
I need to use the laser source as a pulsed mode.
What should I do?
2 Replies Last Post Jan 14, 2015, 1:17 p.m. EST
Posted: 1 decade ago Mar 4, 2013, 1:13 a.m. EST
first of all you have the gp1() (Gaussian pulse, check the help for the normalisation, its slightly hidden ;) under "model - Definitions - Functions". So if you have a pulsed laser and you are interested in the pulse response, you must do a time series over the pulse length (you can use another gp2() for the temporal shape. But if you have a pulse train, you can use the average energy to, all depends where you interest are (or a single pulse response to get the energy balance and an average value thereafter ...
Hi first of all you have the gp1() (Gaussian pulse, check the help for the normalisation, its slightly hidden ;) under "model - Definitions - Functions". So if you have a pulsed laser and you are interested in the pulse response, you must do a time series over the pulse length (you can use another gp2() for the temporal shape. But if you have a pulse train, you can use the average energy to, all depends where you interest are (or a single pulse response to get the energy balance and an average value thereafter ... -- Good luck Ivar
Posted: 1 decade ago Jan 14, 2015, 1:17 p.m. EST
I am trying to generate a model where I can look at the heat dissipation in a plasmonic structure when irradiated by a ns pulsed laser. I have managed to make a model where I can solve the emf simulation and then a time dependant heat transfer simulation, however I think this is modeling a CW laser source. I would like to be able to tell comsol to have a laser source for 30ns and then stop. I was wondering if another study step with just a time dependent step for the heat transfer would work, but I am unsure how to get the temperature data from the first study step to the second. I have attached the model file. Any advice?
