Running FSI examples, "undefined value found"
Hi!,
i am trying to run an fluid-structure example with use of the MEMS module, byt anytime i get the error "undefined value found..." for the variable mod1.v_solid.
So i even downloaded the 2d fsi example from the comsol page and changed there only the geometry (i adapted the boundary condition to this new geometry but i took the same type of bc) I again get the above listed error.
I checked the bc several times....
I wonder, because the undefined values for u_solid apper in such a (x,y) coordinate, which is not involved in the domain for linear elastic model. Is that a problem? Or what i am doing wrong? I spent a lot of time with this.
I have another question. It is poissible to split the structural equation (i.e. the linear elastic model) to several step (something like operator splitting)?
I am trying to overcome this using Laplace equations instead of solid mechanics and solve them together with laminar flow and deformed geometry (ALE) . I take segregated solver, hereby i need inputs from one segregated step to different one. By this approach i have a problem with the FSI-interface condition ( i chose "moving wall") u_wall=u_laplace, where u_laplace is a solution from different segregated solver. The segregated solver for laminar flow does not know the variable u_laplace . Solving both problems in one segregated steps, or using coupled solver helps, but this is not, what i want to. How can i store the solution from one segregated solver and use it (for example as boundary, or initial condition) in the next timestep in another segregated solver?
Thanks for your help!
4 Replies Last Post Mar 13, 2013, 11:01 a.m. EDT
Posted: 1 decade ago Mar 11, 2013, 4:46 a.m. EDT
In the meantime i found out, that taking Poisson ratio=0.5 cause the problem with "undefined value" cited in my firts question. When i took 0.33 as in all comsol examples, comsol started to compute, howerer it was still not converging....
Somebody is familiar with this ?
In the meantime i found out, that taking Poisson ratio=0.5 cause the problem with "undefined value" cited in my firts question. When i took 0.33 as in all comsol examples, comsol started to compute, howerer it was still not converging.... Somebody is familiar with this ?
Posted: 1 decade ago Mar 11, 2013, 3:47 p.m. EDT
certainly ! what does nu=0.5 mea ? check your equations how E and nu is entered into the stiffness matrix. You can find more about this on the Forum if you do a search. nu=0.495 is OK, but at some stage consider to turn on the "pressure" node dependent variable for"nearly incompressible" materials (see the doc too ;)
Hi certainly ! what does nu=0.5 mea ? check your equations how E and nu is entered into the stiffness matrix. You can find more about this on the Forum if you do a search. nu=0.495 is OK, but at some stage consider to turn on the "pressure" node dependent variable for"nearly incompressible" materials (see the doc too ;) -- Good luck Ivar
Posted: 1 decade ago Mar 12, 2013, 7:55 a.m. EDT
Thanks for your reply!
I am not very familiar with the models for solid mechanics, so I had no idea about Poisson ratio. In my (simpflicated) structural model , which i solve with hyperbolic equations nu=0.5 s allowed.
Anyway, the fsi example with nu=0.495 works, but the convergence is still poor.
What about the second question about operator splitting and segregated solvers?
Thanks a lot!
Ann
Thanks for your reply! I am not very familiar with the models for solid mechanics, so I had no idea about Poisson ratio. In my (simpflicated) structural model , which i solve with hyperbolic equations nu=0.5 s allowed. Anyway, the fsi example with nu=0.495 works, but the convergence is still poor. What about the second question about operator splitting and segregated solvers? Thanks a lot! Ann
Posted: 1 decade ago Mar 13, 2013, 11:01 a.m. EDT
check if your material can be considered as nearly incompressible, in which case you should add the tick in the physics setting (but only for the appropriate material, if required add a new linear material domain node, then it solves also for "p" and often its more stable.
If you have enough RAM and your problem is "linear" you might get around quicker by selecting a Direct solver method
Hi check if your material can be considered as nearly incompressible, in which case you should add the tick in the physics setting (but only for the appropriate material, if required add a new linear material domain node, then it solves also for "p" and often its more stable. If you have enough RAM and your problem is "linear" you might get around quicker by selecting a Direct solver method -- Good luck Ivar
