Using both pressure point and outlet with Pressure, no viscous stress?
Hi!
I'm working with natural and forced convection with the aim to design a ventilation/heating system for my master's thesis.
I'm wondering if I need a "Pressure Point Constraint" if I'm using an outlet with "Pressure, no viscous stress" or if they will cause trouble for each other?
Thanks!
1 Reply Last Post Mar 11, 2013, 3:51 p.m. EDT
Posted: 1 decade ago Mar 11, 2013, 3:51 p.m. EDT
pressure use is mostly a "gauge" pressure, hence if you have set p=0 at outlet you have given a fixed value to make the solution unique, so no need to add anyother "p" point value, except if it makes sens for your model.
As p is a dependent variable in CFD and it is obtained by integration you MUST define some fixed P somewhere, either implicit or explicit, else you do not have an unique solution
Check also carefully the pA absolute pressure and how that is defined in the main physics nodes (+ the doc)
Hi pressure use is mostly a "gauge" pressure, hence if you have set p=0 at outlet you have given a fixed value to make the solution unique, so no need to add anyother "p" point value, except if it makes sens for your model. As p is a dependent variable in CFD and it is obtained by integration you MUST define some fixed P somewhere, either implicit or explicit, else you do not have an unique solution Check also carefully the pA absolute pressure and how that is defined in the main physics nodes (+ the doc) -- Good luck Ivar
