External U vs. I
I'm quite new to COMSOL. I generally have doubts where to use external U vs. I or external I vs. U when I want to insert my designed model into a circuit. I think in any of those cases I have to choose the excitation method accordingly, right? Is there a guideline for that?
What exactly is the difference? I tried to compute the model "inductor-in-circuit" in the model library once using the external U vs. I and the other time using external I vs. U. the computation of the model with external U vs. I takes a lot longer but converges and eventually finishes, however the resulting plots for the magnetic flux density norm are very different. So I don't understand how these choices affect the physical reality of the problem and why are the results different?
5 Replies Last Post Nov 16, 2016, 10:37 a.m. EST
Posted: 1 decade ago Mar 19, 2013, 6:44 p.m. EDT
check carefully the doc about U vs I and I vs U. Normally COMSOL will only allow you to connect a CIR "connector" if there is an appropriate Terminal or current source in the other physics
Hi check carefully the doc about U vs I and I vs U. Normally COMSOL will only allow you to connect a CIR "connector" if there is an appropriate Terminal or current source in the other physics -- Good luck Ivar
Posted: 1 decade ago Mar 20, 2013, 4:16 a.m. EDT
Could you please let me know what exactly this document on U vs I and I vs U is?
Hi, Could you please let me know what exactly this document on U vs I and I vs U is? Thanks,
Posted: 1 decade ago Mar 20, 2013, 5:19 a.m. EDT
I used only the "active help" to find quite some explanations, try a search on "U vs I"
Hi I used only the "active help" to find quite some explanations, try a search on "U vs I" -- Good luck Ivar
Sven Friedel COMSOL Employee
Posted: 1 decade ago Mar 20, 2013, 9:26 a.m. EDT
Dear Bahar,
the difference is:
U vs. I is typically measures a current in your PDE model and assigns a source of a prescribed voltage there.
I vs. U is typically measures a voltage in your PDE model and assigns a source of a prescribed current there.
For instance a lumped port in the magnetic fields interface can only be excited with a current, because
voltage is not a variable that is solved for nor contained in the model. Hence you would need to define an I vs. U because you need to assign a current. In many other interfaces, e.g. electrical currents, where you could assign both a driving voltage or a current on a "normal boundary condition", you can use either U vs. I or I vs. U.
Sven
Dear Bahar, the difference is: U vs. I is typically measures a current in your PDE model and assigns a source of a prescribed voltage there. I vs. U is typically measures a voltage in your PDE model and assigns a source of a prescribed current there. For instance a lumped port in the magnetic fields interface can only be excited with a current, because voltage is not a variable that is solved for nor contained in the model. Hence you would need to define an I vs. U because you need to assign a current. In many other interfaces, e.g. electrical currents, where you could assign both a driving voltage or a current on a "normal boundary condition", you can use either U vs. I or I vs. U. Sven
Posted: 8 years ago Nov 16, 2016, 10:37 a.m. EST
When it says arbitrary voltage value put in the External I vs U block. and then I try to excite my device model using a pulsed Voltage source from cir.. What is the impact of the value of voltage given in External I vs U block.
Why is that the model is not getting excited when I used pulsed voltage source values .
< PS : I am using frequency domain study>
Thanks, When it says arbitrary voltage value put in the External I vs U block. and then I try to excite my device model using a pulsed Voltage source from cir.. What is the impact of the value of voltage given in External I vs U block. Why is that the model is not getting excited when I used pulsed voltage source values . < PS : I am using frequency domain study>
