Need help regarding use of optimization tool for inverse heat transfer problem
I have just started using "Comsole V4.2a". Can anyone provide me any tutorial regarding a simple inverse heat transfer problem ? The problem may be finding out thermal conductivity k, using known temperature profile for a 2-D rectangular geometry.
I am finding difficulty in understanding the "Aquifer problem" available in the model library. Thanks
Koushik
1 Reply Last Post Mar 24, 2013, 2:48 p.m. EDT
Posted: 1 decade ago Mar 24, 2013, 2:48 p.m. EDT
there is an example in the model library, forgotten its name try out a search, simple single scalar optimisation can be done without any optimisation module, but if you have complex cases the optimisation modle is pre-cooked and will make you gain quite some time
Hi there is an example in the model library, forgotten its name try out a search, simple single scalar optimisation can be done without any optimisation module, but if you have complex cases the optimisation modle is pre-cooked and will make you gain quite some time -- Good luck Ivar
