Apr 28, 2013, 6:25 a.m. EDT
Hi , anyone might know ?
Apr 29, 2013, 2:12 a.m. EDT
this is a delicate but very important subject, I'm very often needing this capability, but in reduced modal representation, so far I havent managed to get it working efficiently for "true models", a simple canteliever might work.
Check carefully the doc, do a search on "state space", you need to define a probe plot for the output, and define the state space export as a sub node to the solver case, with excitation in and probe out (I wounder now if it isnt rather in frequency domain you should try, rather than true transient)
May 1, 2013, 4:23 a.m. EDT
Hi , thank you for your reply.
in my project i need to define several points to measure the deflection.
it means that i need to define several probs ?
i saw the help file on this problem and tried to work with it but i had several erros on matlab.
is it possible that you will help me with pasting the commands to import the model , adding the probs until i will get reduced matrices ?
thank you in advance for your help.
May 1, 2013, 6:43 a.m. EDT
have you repeated the example oh the help "state space export" for the heat_transient_axi example ?
Jul 23, 2013, 10:11 a.m. EDT
Dear Ivar,
I did repeat the example , but I've got the following problem:
The returned matrix MB is full of zeros so the solution obtained with ode23s is the zero solution. Hence the final y is the constant solution iqual to T0. Completely different from what it was expected.
I'm enclosing the example.
What do you think that might be wrong?
Dear Ivar,
Sep 12, 2013, 1:43 p.m. EDT
Dear all,
I finally came back to this question. I think that the comsol 4.3 tutorial doc example is not correct. Where there is:
M = mphstate(model,'sol1','out',{'Mc' 'MA' 'MB' 'C' 'D'},...
'input','T0', 'output', 'mod1.ppb1');
There should be:
'input','Tinput', 'output', 'mod1.ppb1');
In fact the input parameter's name is Tinput and not T0.
Dear all,
There should be:
Remi Magnard
COMSOL Employee
Sep 13, 2013, 8:45 a.m. EDT
Dear Jorge,
There is indeed a typo in the LiveLink for MATLAB 4.3b documentation, one should read:
M = mphstate(model,'sol1','out',{'Mc' 'MA' 'MB' 'C' 'D' 'x0'},...
u = 1;
T0= 1273.15;
opt = odeset('mass', M.Mc);
func = @(t,x) M.MA*x + M.MB*u;
[t,x] = ode23s(func, [0:10:190], M.x0, opt);
y = M.C*x'+M.D*u+T0;
where T0 is the Temprature value around the linearization point.
Thank you for pointing this out!
Rémi Magnard
Dear Jorge,
u = 1;
T0= 1273.15;
Rémi Magnard
