Integration boundary condition that is probably of circular dependency (dye-sensitized solar cell)
I tried to model the ionic exchange in a dye-sensitized solar cell. The concentration of cations in the electrolyte follows a Boltzmann distribution:
Nc = N0 * exp(-Q/kT). N0 is a constant.
That is, Nc is a variable dependent on N0.
To fulfill ionic conservation, one of the non-local boundary conditions is:
∫Ω Nc*dΩ = N0*Ω , where Ω is the volume of the cell.
That is, the integration of Nc over the entire domain = N0 * volume of the domain.
My question is, how can I fulfill it in Comsol? I know how to add an integration coupling variable (intop1), but what to do next?
Thanks.
3 Replies Last Post Apr 29, 2013, 2:36 p.m. EDT
Posted: 1 decade ago Apr 29, 2013, 1:06 p.m. EDT
have you tried to define your integration operand, and then add a gloval equation sub node to your physics with a variable set to the intop1() ... and thenuse this new dependent variable in your approriate equations ?
Hi have you tried to define your integration operand, and then add a gloval equation sub node to your physics with a variable set to the intop1() ... and thenuse this new dependent variable in your approriate equations ? -- Good luck Ivar
Posted: 1 decade ago Apr 29, 2013, 1:56 p.m. EDT
No I haven't. I don't even know how to do it. Could you explain a little more as to how to do it in Comsol? And what is a sub node?
Thank you.
[QUOTE] Hi have you tried to define your integration operand, and then add a gloval equation sub node to your physics with a variable set to the intop1() ... and thenuse this new dependent variable in your approriate equations ? -- Good luck Ivar [/QUOTE] No I haven't. I don't even know how to do it. Could you explain a little more as to how to do it in Comsol? And what is a sub node? Thank you.
Posted: 1 decade ago Apr 29, 2013, 2:36 p.m. EDT
check the model library (do not forget to update it regularly) there you will find amny examples with usefull hints.
sub node is is a "node" you add to the model tree, byu selecting a main node and righ-tclicking on i,t to see the palette of available sub nodes, these might go quite deep down, and depening one one seting of you physics, you might get new levels of sub-nodes when you righ click further down
Hi check the model library (do not forget to update it regularly) there you will find amny examples with usefull hints. sub node is is a "node" you add to the model tree, byu selecting a main node and righ-tclicking on i,t to see the palette of available sub nodes, these might go quite deep down, and depening one one seting of you physics, you might get new levels of sub-nodes when you righ click further down -- Good luck Ivar
