Creating geometry with loop
Alberto Garcia-Cristobal
Dear All
I am doing some calculations in Mechanics module. My problem is how to create circle with different radius R1.......Rn and do calculation for each radii in loop.
A
2 Replies Last Post May 31, 2013, 4:40 p.m. EDT
Posted: 1 decade ago May 31, 2013, 4:14 p.m. EDT
Alberto-
Use Definitions>Parameters and define your radius as a parameter.
Then, under the Study node right-click and add "Parametric Sweep" node. Then, add the range of which radii you would like to solve for.
Josh Thomas
AltaSim Technologies
Alberto- Use Definitions>Parameters and define your radius as a parameter. Then, under the Study node right-click and add "Parametric Sweep" node. Then, add the range of which radii you would like to solve for. Best regards, Josh Thomas AltaSim Technologies
Posted: 1 decade ago May 31, 2013, 4:40 p.m. EDT
Dear Josh
Thank you, you solved my problems . Have nice weekend !
A.
Dear Josh Thank you, you solved my problems . Have nice weekend ! Regards, A.
