Edgar J. Kaiser
Certified Consultant
Jun 3, 2013, 5:39 p.m. EDT
all quantities in COMSOL can be complex numbers. Use the real() and imag() operators to obtain the complex components and calculate the phase.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
8 years ago
Nov 21, 2016, 8:13 a.m. EST
I have the same problem, and I do not understand where to use the operators.
This is how I proceed. I modeled a piezoelectric bar made of PZT-5H. On one side I apply a ground, and on the other a potential. To calculate the impedance, I use a boundary probe which measures the current density on the same side I apply a potential.
Problem is that the probe only gives me real value. I tried to find a way to have the phase with the probe but do not find how...
Thibaut
Thibaut
8 years ago
Nov 21, 2016, 6:06 p.m. EST
If you integrate the normal component of the electric displacement vector on the electrode surface you will get the charge on the electrode. Then the (complex) current is j*omega*charge.
D.W. Greve
DWGreve Consulting
D.W. Greve
DWGreve Consulting
8 years ago
Nov 22, 2016, 4:39 a.m. EST
I tried this, but this gives me a constant phase of pi/2 over all my frequency range. There are resonances so it should not stay constant.
Just to be sure I do it correctly. I perform a sweep over the frequency range of interest, in a Frequency Domain study. Then, after getting the charge, I multiply every point of my charge vector by the corresponding j*w. Is this right ?
I attach my model, to make sure there is no mistake.
Thibaut
Thibaut
8 years ago
Nov 22, 2016, 10:18 a.m. EST
This does not open properly for me, perhaps because I do not have the CAD import installed right now.
But. Under "derived values" you should calculate a surface average of the normal electric displacement vector. Forget the boundary probe.
And there is an important difference between the norm (or magnitude) of the electric displacement vector (which, by definition, is purely real) and the normal component of the electric displacement on a surface (which will indeed be complex).
8 years ago
Nov 22, 2016, 11:14 a.m. EST
Hi D,
Ok, it seems to work now (either with a probe or with a Surface Average), thank you !
I now have a constant phase shift between the simulation and my measurements, but it may come from the measurement.
Anyway, thank you a lot !
Thibaut
Hi D,
Thibaut
