I really need help with this question! Please
I am soooo stuck with how to draw 2D cut lines from (b) in this solution set. I know its probably something really simple but its driving me crazy. I really don't know how to define the zeta cut lines and make a sketch as generated in the attachment. If someone could please give me some more detailed solution on how to complete step b I would really appreciate it.
I am just a beginner to COMSOL and I am really struggling with this - I have a test on Monday and I know that very similar concepts will be on the test. I am really panicking currently because I have been trying to figure this out for hours and I still can't do it ;(
Please help me.
Thank you a lot!
2 Replies Last Post Jun 6, 2013, 10:24 a.m. EDT
Posted: 1 decade ago Jun 6, 2013, 10:19 a.m. EDT
Isabel,
you have essentially two otions for line plots.
1. You define a 3D or 2D cut line undern the Data Sets node and choose this cut line as the data set in your 1D plot group > line graph
2. You draw a line in your geometry, check 'create selections' and choose this line in the 1D plot group > line graph
Hope this helps
Edgar
Edgar J. Kaiser
www.emphys.com
Isabel, you have essentially two otions for line plots. 1. You define a 3D or 2D cut line undern the Data Sets node and choose this cut line as the data set in your 1D plot group > line graph 2. You draw a line in your geometry, check 'create selections' and choose this line in the 1D plot group > line graph Hope this helps Edgar -- Edgar J. Kaiser http://www.emphys.com
Posted: 1 decade ago Jun 6, 2013, 10:24 a.m. EDT
Hi thankyou for your reply - how do I define the zeta values using the 2D cut line? I don't understand how to put this information into comsol.
