Heat Transfer through 2 physics / Coupling 2 physics
Hello!
Im trying to figure out how to couple the modules "Heat Transfer in Solids" and "Heat Transfer in Porous Media".
I made a simple example. Two blocks on top of each other. On Block has a heat source on the bottom.
One block is a solid, the other one a porous media. How can I couple/connect them so the heat goes through both blocks?
You can find my model in the attachment.
I tried to use pairs in combination with the Continuity feature, but failed.
Any help is appreciated. Thanks.
Christian
0 Replies Last Post Jun 13, 2013, 11:13 a.m. EDT
Hello Christian Beck
