How can I simulate microwave 2.45GHz interference in nanoparticles?
Posted Jun 23, 2013, 11:40 a.m. EDT RF & Microwave Engineering 0 Replies
Even when I try reproduce a plane wave with 12 cm wavelength in an empty space cube with a small dimension, inferior or equal to 10 micrometers the same error appears:
Failed to find a solution.
The relative error (0.37) is greater than the relative tolerance.
Returned solution is not converged.
You will probably find this error as well if you simply decrease the dimensions of the periodic_boundary_condition model.
Hello Ricardo Mimoso
