Tube diffusion
Hello all,
So I have flow through a cylinder, and want to inject some sort of dye into it. I made a cylinder, and then extruded a circle on the edge to simulate the injection point where I will have some sort of inflow or flux of concentration. For some reason the mesh is not generating around the circle. I'm not sure if I did it right, but any suggestions would be helpful! I attached the file if anyone wants to look. Thanks!
Jon
1 Reply Last Post Jul 4, 2013, 8:45 a.m. EDT
Posted: 1 decade ago Jul 4, 2013, 8:45 a.m. EDT
Dear Jonatan,
I'm working with a bit similar problem. I just made a sphere inside the flow with continuity boundary conditions for fluid and fix a reaction rate for diluted species. I have no problems with meshing for such a decision. Good luck
Evgeny
Dear Jonatan, I'm working with a bit similar problem. I just made a sphere inside the flow with continuity boundary conditions for fluid and fix a reaction rate for diluted species. I have no problems with meshing for such a decision. Good luck Evgeny
