Edgar J. Kaiser
Certified Consultant
Jun 28, 2013, 5:11 p.m. EDT
Hi Neil,
you have to add a terminal or a port to the coil.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Hi Neil,
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
Jun 30, 2013, 8:56 a.m. EDT
this model maybe helpful to you, and the induced voltages both in the primary and the secondary windings are calculated. It may be a little complex than your model.
www.comsol.com/showroom/gallery/14123/
http://www.comsol.com/showroom/gallery/14123/
Jul 2, 2013, 1:57 p.m. EDT
Hi Neil,
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Hi Edgar, thanks for your reply.
Would you mind giving a bit more information - how do I use a terminal/port?
[QUOTE]
Hi Neil,
Cheers
Edgar
Edgar J. Kaiser
[/QUOTE]
Jul 2, 2013, 2:16 p.m. EDT
Thanks, that is helpful.
I've tried to modify that example until it's just like what I'm modeling, but I've encountered another problem. As soon as the coils move apart (in my model they are beside each other, not one within the other), the solution no longer converges. I've attached the model, and if you vary the coil_dist parameter from 14mm to 16mm you will see that it suddenly stops converging. Do you have any idea why this might be?
[QUOTE]
[/QUOTE]
Jul 31, 2013, 4:22 a.m. EDT
i think you have to make shure that the coil-domains did not intersect with each other. Also as the geometry changes doublecheck the allocation of the coilin respect eg. ports or reference edges.
[QUOTE]
[QUOTE]
[/QUOTE]
[/QUOTE]
