Using a function for Permeability value
Hello!
I am new to the software. I am modeling fluid flow through the annulus of a pipe coupled to a porous media and am using the Free and Porous Media Flow physics interface. The permeability of the porous material is a function dependant on length of the material. The equation (from experimental data) is: f(x)=exp(-0.077*x+3.9)
It will not let me put this in directly because:
a) x is only in meters, not meters squared
b) it is having trouble understanding exp(x), instead of just a value
Any ideas are appreciated!
Amber
2 Replies Last Post Jul 16, 2013, 11:15 a.m. EDT
Posted: 1 decade ago Jul 15, 2013, 3:41 p.m. EDT
Amber-
Use:
exp(-0.077*x[1/m]+3.9)[m^2]
Your function f(x) I bet is units of m^2. These are the correct units for permeability.
Also, I think you should be reading in the x dimension as unitless by adding the [1/m] after x.
My guess is that you were getting the expression to turn orange which is not a fatal error (usually just a units warning). You should, however, get a black expression if you use the function I gave above. As long as the expression in your edit field isn't red you will still be able to run the model (you just may have incorrect units).
Josh Thomas
AltaSim Technologies
Amber- Use: exp(-0.077*x[1/m]+3.9)[m^2] Your function f(x) I bet is units of m^2. These are the correct units for permeability. Also, I think you should be reading in the x dimension as unitless by adding the [1/m] after x. My guess is that you were getting the expression to turn orange which is not a fatal error (usually just a units warning). You should, however, get a black expression if you use the function I gave above. As long as the expression in your edit field isn't red you will still be able to run the model (you just may have incorrect units). Best regards, Josh Thomas AltaSim Technologies
Posted: 1 decade ago Jul 16, 2013, 11:15 a.m. EDT
Mr. Thomas,
Thank you for your response! That worked perfect. I appreciate the help!
Sincerely,
Amber
Mr. Thomas, Thank you for your response! That worked perfect. I appreciate the help! Sincerely, Amber
