How to change colour scale bar width?
I am using COMSOL 4.2a and when I export post processing image then the scale bar in the image is very thin and almost invisible at the same time the range of values is also not visible. So I want to change(increase) the width of the scale bar in order to get it visible on the exported post-processing image.How should I proceed??
2 Replies Last Post Jul 26, 2013, 2:53 a.m. EDT
Posted: 1 decade ago Jul 22, 2013, 10:56 a.m. EDT
Jayant-
Change Size from Current to Manual.
Then, try playing with the Resolution and Font Size. Tweaking these values should give you what you are looking for.
Josh Thomas
AltaSim Technologies
Jayant- Change Size from Current to Manual. Then, try playing with the Resolution and Font Size. Tweaking these values should give you what you are looking for. Best regards, Josh Thomas AltaSim Technologies
Posted: 1 decade ago Jul 26, 2013, 2:53 a.m. EDT
Hello Josh,
Thanks,Its working.
Jayant
Hello Josh, Thanks,Its working. Jayant
