S-parameter and port BC
Farhad Kazemi Khosroshahi
Hi everyone
I am studying the emissivity of a surface. In order to consider higher orders of reflection or transmission, we need to add several port BCs. for example in my case I am trying to obtain the reflectivity and transmissivity for m=0,+-1,+-2,+-3 orders. in this case we need to define 14 port BC.
in this case, for example, " abs(emw.S11)^2 " gives the zero order reflectivity. But for orders higher than 2 we can not define such expression. In fact, COMSOL does not accept " abs(emw.S101)^2 " which refers to the row 10 and column 1 of the S-matrix. We can define only the following expressions:
abs(emw.S11)^2
abs(emw.S21)^2
abs(emw.S31)^2
abs(emw.S41)^2
abs(emw.S51)^2
abs(emw.S61)^2
abs(emw.S71)^2
abs(emw.S81)^2
abs(emw.S91)^2
I need to define the following expressions as well but after typing the turn to orange
abs(emw.S101)^2
abs(emw.S111)^2
abs(emw.S121)^2
abs(emw.S131)^2
abs(emw.S141)^2
does anybody knows what is going wrong?
2 Replies Last Post Aug 24, 2015, 5:38 a.m. EDT
Hello Farhad Kazemi Khosroshahi
Posted: 9 years ago Aug 23, 2015, 7:19 p.m. EDT
I also want to know what is going wrong. Have you woked out any approach to solve this problem?
Thank you!
Hello, I also want to know what is going wrong. Have you woked out any approach to solve this problem? Thank you!
Posted: 9 years ago Aug 24, 2015, 5:38 a.m. EDT
try: abs(emw.S10_1)^2
it seems that COMSOL changes notation for port 10 and above and adds un underscore "_" to distinguish the items
Check in the Equation View for your version, this is for my v.5.1.0.180
Hi try: abs(emw.S10_1)^2 it seems that COMSOL changes notation for port 10 and above and adds un underscore "_" to distinguish the items Check in the Equation View for your version, this is for my v.5.1.0.180 -- Good luck Ivar
