Penetration and convergence in contact; viscoplasticity
Hi!
My ultimate goal is to simulate metal extrusion, specifically interested in the streamlines of the metal flow as the billet deforms in the die. I'm applying a prescribed velocity at the top surface of the billet, which starts as a cylinder sitting in the container. I am trying to use the Anand material model, available with the Viscoplasticity node, from the Nonlinear Structural Materials Module. All my models have been axisymmetric.
My first question is:
Is this feasible? I was hoping to apply remeshing as large deformation is occurring.
I'm using the Solid Mechanics module, using of course a constant temperature for the Anand model. I started with a transient model. However, I was having penetration of the billet into the die wall. Reading about contact, I implemented the penalty formulation found in the model "Contact Analysis of a Snap Hook Using a Penalty Formulation". To do this, I used a stationary study and a linear elastic material: aluminum billet (or cylinder) contacting a flat, thick plate (fixed constraint). I also implemented parametric sweep for solving. It worked up to a point, then it didn't converge. I plan to play around with the penalty factor.
I tried to use the Viscoplasticity material model (Anand model) to see if it worked at all, but I get an error about empty rows for the creep strain (solid.ece).
Any help, thoughts, tips, etc are greatly appreciated! I've been trying for so long!!
0 Replies Last Post Aug 6, 2013, 3:13 p.m. EDT
Hello Sylvana Garcia
