Accessing prior solutions while solving a Time-Dependent Study
Posted Aug 7, 2013, 1:58 p.m. EDT Heat Transfer & Phase Change, Parameters, Variables, & Functions, Studies & Solvers Version 4.3b 0 Replies
Right now I've only been able to create a conditional statement that will deactivate perfusion if the current solved temperature is greater than the threshold. The issue is that during my modeling, the tissue undergoes successive heating/cooling cycles. So when the current temperature falls below that threshold, perfusion kicks back in again. Instead, I would like perfusion to be permanently disabled at that node once the temperature threshold has been exceeded.
Is there a simple way to call the maximum temperature (or any solved variable) for each node from any prior time point while solving a time-dependent study?
Thanks for any help/suggestions.
Hello Vasant Salgaonkar
