Linear elastic material
Sahar Hashemgeloogerdi
I implied two linear solid mechanic (linear elastic material) in two rectangular(( Rectangular1)and rectangular2 ) ), there is a common inner boundary( number 2) between these two rectangular, i imposed the displacement of 1cm at this boundary 2 in the fallowing figure to see the behavior of the mechanical stress:
My problem is that when I use the identity pair for the boundary 2 and then use continuity for it , I got this error :
"Illegal domain selection".
- Pair: p1
I---------------------------------I(1)
I--------------------------------I (2)
I---------------------------------I(3)
thank you so much
1 Reply Last Post Aug 19, 2013, 11:00 a.m. EDT
Posted: 1 decade ago Aug 19, 2013, 11:00 a.m. EDT
Hi Sahar,
have you tried to use Union instead of Assembly? Or you have some reason of using Assembly?
Regards
Hi Sahar, have you tried to use Union instead of Assembly? Or you have some reason of using Assembly? Regards
