Sven Friedel
COMSOL Employee
Aug 21, 2013, 4:05 a.m. EDT
Hi Jürgen,
we would need to know a bit better what kind of expressions you want to display.
Note that if you have integrals to be evaluated and maybe integrals of integrals: such evaluations are done only during the postprocessing, and all over again. If you want to have such outputs quickly, you can define an ODE with a degree of freedom in whcih the reult of that expression is stored. Then it is part of the solution and can be displayed right away.
If this does not help, feel free to send us a workable example in support, i.e. a file that si not GB big and takes hours but sufficeintly small and fast but illustrates your problem. If necessary use our FTP site to submit the file.
Sven
Hi Jürgen,
Sven
Aug 21, 2013, 8:59 a.m. EDT
Dear Sven,
thanks for your quick and helpful reply.
There are indeed some "intops" in the global plot expressions. I was not aware of the fact that integrals are evaluated "live" during postprocessing.
As you suggested I have put these integrals into an ODE and I am currently running the model to see if it improves the speed of graphical output.
If it does not help I would like to come back to your offer and send you a small example model that illustrates the problem.
Thanks and best regards,
Juergen
Dear Sven,
Juergen
Edgar J. Kaiser
Certified Consultant
Aug 21, 2013, 9:17 a.m. EDT
Hi Sven and Jürgen,
I am sometimes encountering this issue when doing far field plots in RF simulations. It is not that bad for line plots like polar antenna pattern diagrams, but it gets really time consuming in any 3D plots. Fortunately for the quantitative work the polar plots mostly do the job and 3D patterns are a nice to have. But sometimes you would like to have them, and then it easily takes longer than the solution time.
Could implementing the respective equations to make the far field data part of the solution be a good way here? Is COMSOL considering this in order to make far field plots easier and quicker? Or would we just extend the time for solving this way?
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
Hi Sven and Jürgen,
Cheers
Edgar
Edgar J. Kaiser
Magnus Olsson
COMSOL Employee
Aug 21, 2013, 10:31 a.m. EDT
Hi Edgar,
Are you making use of the 3D far field plot feature where you have explicit control over the phi and theta resolution? Compared to plotting the far field on for example a boundary, that should be a lot faster. When plotting the far field on radiation boundaries, the required mesh resolution (lambda/5) is usually unnecessarily fine for plotting far fields which makes it slow.
We could indeed compute the far field as an extra step during solution but it would not be any faster. I recommend to use the 3D far field plot feature with coarse phi and theta resolution and request a finer plot when needed.
Magnus
Hi Edgar,
Magnus
