Results - Density current
I'm current working in a 2D simulation of a conceptual motor and I need some help interpreting the results.
I defined a copper conductor as the boundary of a cylinder of iron. The copper conductor has a surface density current [A/m]. After computing, when I use a "1D plot - line graph" to check the density current on that surface, the result is in [A/m^2] and not in [A/m]. Why?
I also was especting a Lorenz force contribution on that surface with the units [N/m^2] but the result is in [N/m^3].
Can someone explain me why is that?
Thanks for your atention,
Best reggards,
João Fernandes
4 Replies Last Post Sep 12, 2013, 4:50 a.m. EDT
Posted: 1 decade ago Sep 11, 2013, 8:28 a.m. EDT
Hallo,
which exact quantity are you plotting?
For me mf.Jsz is in A/m and mf.Jz is in A/m^2, as I expect.
Regards
Jens
Hallo, which exact quantity are you plotting? For me mf.Jsz is in A/m and mf.Jz is in A/m^2, as I expect. Regards Jens
Posted: 1 decade ago Sep 11, 2013, 8:41 a.m. EDT
Now i realise that i was ploting mf.JZ so the units were in [A/m^2].
But i also have a conductive layer (surface) next to the current surface that i defined. I was expecting to induce a density current [A/m] on the conductive layer, but the only option to plot inductive currents is mf.JiZ.
I am trying to compare the amplitude of the density currents but one is [A/m] (source) and the other is [A/m^2] (induced). How can i have both in the same units?
Best reggards,
João
Hi, Now i realise that i was ploting mf.JZ so the units were in [A/m^2]. But i also have a conductive layer (surface) next to the current surface that i defined. I was expecting to induce a density current [A/m] on the conductive layer, but the only option to plot inductive currents is mf.JiZ. I am trying to compare the amplitude of the density currents but one is [A/m] (source) and the other is [A/m^2] (induced). How can i have both in the same units? Best reggards, João
Posted: 1 decade ago Sep 12, 2013, 4:35 a.m. EDT
Hi Joao,
If I understand you correctly, you have:
A: a circle (area=0) with surface current density in A/m
B: a ring (area>0) with volume current density in A/m^2
If you integrate Jz in B along the thickness, that would be
give a surface current density in A/m. Is that what you are looking
for?
You would use a general projection to perform such an integration.
Regards
jens
Hi Joao, If I understand you correctly, you have: A: a circle (area=0) with surface current density in A/m B: a ring (area>0) with volume current density in A/m^2 If you integrate Jz in B along the thickness, that would be give a surface current density in A/m. Is that what you are looking for? You would use a general projection to perform such an integration. Regards jens
Posted: 1 decade ago Sep 12, 2013, 4:50 a.m. EDT
Hello Jens,
The figure in annex better explains what I was saying. (Check attach file)
I realized that I can define materials as surfaces (without area). Now I ask if I can induce a current on that surface (on conductive material in figure). If I can, than how can I plot the induced current density in [A/m] to compare with the source density current?
The only plot I can do now is showing me the induced current as [A/m^2], but the conductive material is one surface (without area). How can I convert to [A/m]?
I hope now is easy to understand and thanks for your help.
The best regards,
João
Hello Jens, The figure in annex better explains what I was saying. (Check attach file) I realized that I can define materials as surfaces (without area). Now I ask if I can induce a current on that surface (on conductive material in figure). If I can, than how can I plot the induced current density in [A/m] to compare with the source density current? The only plot I can do now is showing me the induced current as [A/m^2], but the conductive material is one surface (without area). How can I convert to [A/m]? I hope now is easy to understand and thanks for your help. The best regards, João
