Changing geometry etc. between study steps
I've got a rather exotic problem at hand.
I want to use the Livelink to Matlab of COMSOL 4.3b to simulate an evolving system. I am using the Diluted Species Package.
So I start with a configuration (some geometry and reactions etc.) and start a time dependent study step. After the study step ends, I examine the data and generate new geometric objects which also execute reactions etc.
Then a new study step starts with the last data from the old study step and the pattern is repeated in a loop.
But how do I do this correctly? My order is
1) Run first study step
2) Build new geometric objects using the original geometry-name like this
### model.geom('geom1').feature.create('elp1', 'Ellipsoid');
3) Run the geometry
### model.geom('geom1').run;
4) Add the new objects to a selection and add it to the diluted species physics
### model.physics('chds').selection.named('newobjects_union_dom');
5) Add the reactions to these union.
6) Run the next study step like this:
### model.sol('sol1').feature('st2').name('Compile Equations: Time Dependent 2 (2)');
### model.sol('sol1').feature('st2').set('studystep', 'time2');
### model.sol('sol1').feature('v2').set('solnum', 'last');
### model.sol('sol1').feature('v2').set('notsolmethod', 'sol');
### model.sol('sol1').feature('v2').set('initsol', 'sol1');
### model.sol('sol1').feature('v2').set('notsolnum', 'auto');
### model.sol('sol1').feature('v2').set('notsol', 'sol1');
### model.sol('sol1').feature('v2').set('control', 'time2');
### model.sol('sol1').feature('v2').set('initmethod', 'sol');
### model.sol('sol1').feature('t2').set('tout', 'tsteps');
### model.sol('sol1').feature('t2').set('tlist', 'range(0,0.1,3)');
### model.sol('sol1').feature('t2').set('maxorder', '2');
### model.sol('sol1').feature('t2').feature('fc1').set('damp', '0.9');
### model.sol('sol1').feature('t2').feature('fc1').set('jtech', 'once');
### model.sol('sol1').feature('t2').feature('fc1').set('maxiter', '8');
### model.sol('sol1').feature('t2').feature('i1').set('rhob', '20');
### model.sol('sol1').feature('t2').feature('i1').feature('mg1').feature('pr').feature('sl1').set('relax', '0.5');
### model.sol('sol1').feature('t2').feature('i1').feature('mg1').feature('pr').feature('sl1').set('linerelax', '0.2');
### model.sol('sol1').feature('t2').feature('i1').feature('mg1').feature('pr').feature('sl1').set('seconditer', '2');
### model.sol('sol1').feature('t2').feature('i1').feature('mg1').feature('po').feature('sl1').set('relax', '0.5');
### model.sol('sol1').feature('t2').feature('i1').feature('mg1').feature('po').feature('sl1').set('linerelax', '0.2');
### model.sol('sol1').feature('t2').feature('i1').feature('mg1').feature('po').feature('sl1').set('seconditer', '2');
### model.sol('sol1').feature('t2').feature('i1').feature('mg1').feature('cs').feature('d1').set('linsolver', 'pardiso');
### model.sol('sol1').runAll;
### figure
### mphplot(model, 'pg2');
The problem is now that mphplot gives me a slice of substrate distribution if I execute it directly after step one. In the order above I dont get a slice and I don't know if anything at all was calculated.
Do I have to remesh or something like this? Does this keep the old values from step 1 valid for step 2?
Any ideas how to approach this? Thank you very much!
Damian
1 Reply Last Post Feb 14, 2014, 1:56 p.m. EST
Hello Damian Kösters
Posted: 1 decade ago Feb 14, 2014, 1:56 p.m. EST
I've been running into a similar problem.
In my model, I have 2 for loops: evaluating at 'j' for each 'i' (thus having jxi solutions). 'i' changes without problem and records the data, however, when 'j' is modified an error occurs.
I can tell it's not a problem with my actual parameters/meshing because I can run the model with the exact same parameters in just comsol (not livelink) no problem.
I've also tried running the parameters at 'j' and 'i' in livelink, this also produced no problems for me.
My potential solution is to clear the mesh/model between each run. >ModelUtil.clear
This didn't work for my problem, but maybe it'll work for yours?
I've been running into a similar problem. In my model, I have 2 for loops: evaluating at 'j' for each 'i' (thus having jxi solutions). 'i' changes without problem and records the data, however, when 'j' is modified an error occurs. I can tell it's not a problem with my actual parameters/meshing because I can run the model with the exact same parameters in just comsol (not livelink) no problem. I've also tried running the parameters at 'j' and 'i' in livelink, this also produced no problems for me. My potential solution is to clear the mesh/model between each run. >ModelUtil.clear This didn't work for my problem, but maybe it'll work for yours?
