Lorentz force calculation
I am trying to obtain the Lorentz force generated by a coil to a workpiece. I am integrating the Lorentz force over the entire domain (i.e. workpiece), but I was just wondering if COMSOL uses the average force experienced by the workpiece to do that calculation. If I understood it right, force is concentrated on the surface, specifically on the area directly above the coil (assuming workpiece is above the coil and is wider than the coil)?
1 Reply Last Post Nov 30, 2014, 12:34 p.m. EST
Hello Diana David
Posted: 10 years ago Nov 30, 2014, 12:34 p.m. EST
Did you find a solution ? As I have the same problem as yours
Thanks a lot
BR
Mohamed
Hi, Did you find a solution ? As I have the same problem as yours Thanks a lot BR Mohamed
