results change with time range
I'm doing a time-dependent heat transfer simulation. Under "Study Settings", I change the range in the "Times" field from (0,1,100) to (0,1,1000) and then compare the solution at different time points included in both ranges (i.e. 1, 10, 100). The solution is different (by 15-20K) and the only thing I changed was the time range to output. Why is this? I thought COMSOL has it's own algorithm for choosing the time step ... the time range I specify in the "Times" field is just the range of solution values that it stores so I can access them. But shouldn't both solutions be the same for time = 10s or time = 100s or whatever? I didn't change anything but the time range.
2 Replies Last Post Oct 22, 2013, 7:06 p.m. EDT
Posted: 1 decade ago Oct 22, 2013, 3:30 p.m. EDT
Travis,
Check out this thread. It might help you understand what is going on:
www.comsol.com/community/forums/general/thread/39634
Josh Thomas
AltaSim Technologies
Travis, Check out this thread. It might help you understand what is going on: http://www.comsol.com/community/forums/general/thread/39634 -- Best regards, Josh Thomas AltaSim Technologies
Posted: 1 decade ago Oct 22, 2013, 7:06 p.m. EDT
That was helpful, thanks!
