Two laminar flow fluids mixing due to diffusion
In a microfluidic domain, fluids (which don't react with each other) may mix only by diffusion. So if I have two different fluids, having different inlets and a common outlet (lets assume a T- junction), with diffusion coefficients given, how would I go about simulating it ? I get stuck at how would I define such a domain and how would I couple the two physics. I am a novice.
Thank you for your help and time !
1 Reply Last Post Aug 4, 2015, 7:00 p.m. EDT
Hello Abhishek Kumar
Karupothula Prashanth
Posted: 10 years ago Aug 4, 2015, 7:00 p.m. EDT
Hi Abhishek,
I am also facing the same problem. Please help me if you found it.
Hi Abhishek, I am also facing the same problem. Please help me if you found it.
