Solving Pooisson/Laplace Equation for Multi-Electrode Array
Dear All,
Iḿ trying to use Comsol to solve the laplace equation within a 3-D space.
This 3D space is limitted by a block of 8000x8000x500um.
The Top-Plane xy,500 should be at ground (V=0V).
The potentials at the side (x,4000,z), (x,-4000,z), (4000,y,z),(-4000,y,z) should form a zero-flux boundary with dV/dn=0.
on the electrodes with diameter D/2 and spacing S there should be a current flowing with dV/dn=i/(pi*(D/2)^2).
I build this within the attached model.
The solver cannot solve this problem. Iḿ getting an error that the threshold is reached.
Could anyone help please?
It is also possible that I did some error within the boundary definition or the choice of the physics.
If there could anyone check I would be really greatful.
kind regards
1 Reply Last Post Nov 5, 2013, 5:56 a.m. EST
Bettina Schieche COMSOL Employee
Posted: 1 decade ago Nov 5, 2013, 5:56 a.m. EST
Dear Ms. Rieger,
I had a quick glance at your model and noticed that you did not use "Constraint 1" correctly. Please have a look at the equation, which reads "R=0". So, in order to achieve u=0, you need to enter your dependend variable "u" in the expression field for "R". Maybe the "Dirichlet Boundary Condition" is more intuitive for you.
Best regards
Bettina Schieche
Dear Ms. Rieger, I had a quick glance at your model and noticed that you did not use "Constraint 1" correctly. Please have a look at the equation, which reads "R=0". So, in order to achieve u=0, you need to enter your dependend variable "u" in the expression field for "R". Maybe the "Dirichlet Boundary Condition" is more intuitive for you. Best regards Bettina Schieche
