Discrepancies using periodic ports at off-normal incidence
COMSOL'ers:
When performing 2-D full-field simulations of an opaque periodic structure at off-normal incidence, my results (near- and far-field profiles) vary as a function of the height of the upper (air) region. At normal incidence, however, there is good agreement.I know this topic has been addressed, but I have accounted for the solutions presented previously, such as meshing, diffraction orders, and reflections.
Model included. My BC's are Floquet PBC on the sides, impedance BC on the bottom (aluminum substrate) and a port with diffraction orders on the upper boundary.
At an angle, the phase distribution would shift as I change the height of the air port--is this the source of my disrepancy? I have tried adding a phase shift such as ky*delta_h, where delta_h is the change in height from a baseline model (height of 4*period), but the two results still differ significantly.
Any thoughts?
Thanks for your attention!
-ado
3 Replies Last Post Nov 13, 2013, 1:18 p.m. EST
Magnus Olsson COMSOL Employee
Posted: 1 decade ago Nov 7, 2013, 4:35 a.m. EST
The problem is that you have defined the "Port phase" on the periodic port as:
phi_shift = {see variable definition} = exp(-j*kaz*delta_h)
This should be the phase angle as seen from the desired unit [rad].
Change the variable definition to;
phi_shift = -kaz*delta_h
and it will work.
Magnus
Hi, The problem is that you have defined the "Port phase" on the periodic port as: phi_shift = {see variable definition} = exp(-j*kaz*delta_h) This should be the phase angle as seen from the desired unit [rad]. Change the variable definition to; phi_shift = -kaz*delta_h and it will work. -- Magnus
Posted: 1 decade ago Nov 13, 2013, 1:17 p.m. EST
Magnus: I failed to mention I tried both ways--the model just had the last (and I assumed incorrect) phase input.
Posted: 1 decade ago Nov 13, 2013, 1:18 p.m. EST
SOLVED:
I thought I would post the final solution to this issue, which was presented to me by the online support team. My default angle of incidence was set to theta=0, and so my diffraction order calculation only accounted for the +1 & -1 orders. I needed to include the orders at the full angular span of the model, which, in my case, added a very significant -2 order. Now, incorporating the phase advance into the port and diffraction order phases properly gives identical solutions at any port length.
Another problem that occured was that a strong field appeared near the ports once the diffraction orders were added. Apparently this was solved in the most recent patch (v.4.3.2.189), while I am at v.4.3.2.164.
Thanks, support team!
SOLVED: I thought I would post the final solution to this issue, which was presented to me by the online support team. My default angle of incidence was set to theta=0, and so my diffraction order calculation only accounted for the +1 & -1 orders. I needed to include the orders at the full angular span of the model, which, in my case, added a very significant -2 order. Now, incorporating the phase advance into the port and diffraction order phases properly gives identical solutions at any port length. Another problem that occured was that a strong field appeared near the ports once the diffraction orders were added. Apparently this was solved in the most recent patch (v.4.3.2.189), while I am at v.4.3.2.164. Thanks, support team!
