2D Depth in 4.3a
I am relatively new to COMSOL. I am using version 4.3a. My issue is with heat transfer in solids, specifically the depth to my geometry. It is my understanding that the default depth is 1m. Since my model's scale is much smaller than this, mm, it throws off all off the calculations.
My question is how do I change the default depth to a specified depth. Should I simply make a 3d model instead? I was hoping to compare both 2d and 3d computations.
Thank you for any advice/help
1 Reply Last Post Feb 18, 2014, 10:51 a.m. EST
Hello Kegan Dellinger
Posted: 1 decade ago Feb 18, 2014, 10:51 a.m. EST
Hi!, I have the same problem, do you have new news?
Thanks in advance.
Hi!, I have the same problem, do you have new news? Thanks in advance.
