Elliptical cylinder
André Ødegårdstuen
I am completely new to comsol, so please forgive me for posting a problem I suspect have a simple solution. I have tried to search for a solution myself, unsuccessfully.
In a microfluidic problem I need to use a pipe with an elliptical cross section. I have attempted to use a parametric surface and then convert it to a solid, but I get a warning that the output is empty.
Any help or tips would be much appreciated.
3 Replies Last Post Jun 8, 2016, 9:15 p.m. EDT
Hello André Ødegårdstuen
Posted: 9 years ago Jun 8, 2016, 10:34 a.m. EDT
Hi André,
I'm facing the same problem. Have you found the solution? Thanks!
Ningyu
Hi André, I'm facing the same problem. Have you found the solution? Thanks! Best, Ningyu
Posted: 9 years ago Jun 8, 2016, 10:48 a.m. EDT
You can draw an ellipse in a workplane and extrude it.
You can draw an ellipse in a workplane and extrude it. Best regards, Jeff
Posted: 9 years ago Jun 8, 2016, 9:15 p.m. EDT
It works. Thanks a lot!
