Hello Soumendu
Jul 7, 2014, 6:30 a.m. EDT
Hey Soumendu,
I am getting a similar error. Did you come up with solution. I am trying to use SiO2 as insulator but it shows a red cross on Materials and SiO2 in the model builder. While using semiconductor module can we use material other than given in semiconductor material like SiO2 or any metal.
-Anup Kumar
Hey Soumendu,
-Anup Kumar
Aug 15, 2014, 5:30 a.m. EDT
Hi, Soumendu
Check mesh in your model (is it too fine?) or maybe this problem is due to missing boundary condition.
Hi, Soumendu
Aug 15, 2014, 6:02 a.m. EDT
Hi, Anup
If you add Charge Conservation node related to SiO2 domain, red cross will disappear.
In my opinion, when you use Semiconductor Module, COMSOL think that all domains are semiconductors by definition and for this reason COMSOL ask you to define all parameters required by physics (band gap, electron affinity etc.). But you can include insulator in the model by using Charge Conservation feature. As a result you need to specify only relative permittivity to describe SiO2 (actually relative permittivity or polarization or remanent electric displacement - it's your choice in Charge Conservation settings window -> Electric Field)
Hope this helps!
Hi, Anup
Hope this helps!
9 years ago
Feb 21, 2016, 8:27 a.m. EST
I'm trying to simulate MOSFET using explicit SiO2 as gate oxide instead of using thin insulator gate. Although applying charge conservation to SiO2 layer only require dielectric constant of SiO2 to define, but it is not allowing me to use metal contact or terminal on the top surface of SiO2 layer. Also, if I use an extra gate material, it requires all semiconductor parameters, which are not available for metals. So is there any other physics or boundary or domain condition I have to use to simulate?
Please look into it and any suggestion will be highly appreciable.
Thank you,
Thank you,
8 years ago
Dec 29, 2016, 9:50 p.m. EST
I'm facing a same problem of metal layers simulation in Semiconductor module.
Have you able to solve it?
