Hello Matthew Cox
10 years ago
Jul 28, 2015, 1:15 p.m. EDT
I have the same problem, did you solve your problem?
I want to import a set of points with different x,y and z coordinates.
Cheers
Sepideh
Cheers
Sepideh
10 years ago
Jul 28, 2015, 1:39 p.m. EDT
Hi Sepideh,
I was not able to figure this out with COMSOL. I switched to using SIMION for particle tracing which was much more flexible on the particle properties (scripts can be used to change particle properties during flight).
Hi Sepideh,
10 years ago
Aug 17, 2015, 4:51 a.m. EDT
In the latest version of Comsol Particle tracing Module you can now import a set of particle starting points, directions and other properties from a file, which is very useful.
You can also define starting cords in the provided physics interface and tell it to use all combinations or selected combinations. The only thing you can't do yet is use parameters in input fields which can take a list and you have to use literal (fixed ) numbers or functions based on literal numbers.
So I'd give Comsol 8 out of 10 for this so far. If they extend it so you can use parameters in all the input fields then I'd give them 10 out of 10.
Daniel Smith
COMSOL Employee
10 years ago
Aug 17, 2015, 9:34 a.m. EDT
Hi Matthew, the ability to use parameters for the Initial Coordinates in the Release from Grid feature will be available in the next version, V5.2. You will also be able to use parameters in the Release times edit field.
Thank you for the feedback.
Dan
Dan
10 years ago
Aug 19, 2015, 9:56 a.m. EDT
Sounds good - when is Comsol 5.2 expected to be released?
