Hello Pavel Kliuiev
Mohammad Parvinnezhad Hokmabadi
Aug 30, 2014, 10:23 p.m. EDT
Do you still need?
I am working on the same and I know how to set.
If you still need let me know.
Mohammad
Do you still need?
Mohammad
10 years ago
Oct 22, 2015, 2:20 a.m. EDT
Hello! Mohammad,
I'm also very confused about how to set the background scattering field when a substrate exists and this step is aimed to solve the next scattering field when there is a gold nanoparticle on it. I tried to solve the problem refer to the example "scatter on substrate" but the result of extinction cross section at long wavelength is very large. So, I guess the background must be set in a wrong way. Would you tell me how to solve the problem? The plane wave at the normal incidence.
Thank you very much!
Ran Jia
Hello! Mohammad,
Ran Jia
8 years ago
Apr 12, 2017, 2:01 a.m. EDT
Mohammad Parvinnezhad Hokmabadi,
Can we define the source like dark field source a cone like a source into the COMSOL, if so can you help me to do so???
8 years ago
Jul 15, 2017, 11:05 a.m. EDT
Dear Mohammad,
I am trying to find the scattering,absorption and extinction cross sections of a gold nano disk with 50 nm height and 80 nm diameter on glass substrate. I followed the 'scatterer on substrate' tutorial for COMSOL 5.1 but failed. It gave correct result for total field solutions, power reflection coefficients in the first part i.e. Air glass interface without scatterer but for the 2nd part, i.e. scatterer with background field as superposition of reflected, incident and transmitted field of first part, it gave scattering cross sections as zero for all wavelengths. The absorption and extinction cross sections are also wrong but non zero and decreasing with wavelength increment. Is it possible to input the background field analytically and only using PMLs than ports. Could you please help me that how can I analytically assign the superposition of reflected and incident field in upper side and transmitted field in substrate side for the scatterer (then no need of ports and first part complexity can be overcomes) ? For my case it is normal incidence of light and the 'scatterer on substrate' tutorial is much complex and (unnecessarily critical) for normal incidence case. i find also that Floquet condition seems not needed for normal incidence.
Could you please share your experience on it.
Dear Mohammad,
